Hello? I have a GMC 320 I purchased to monitor potential radiation emitting from a project I am working on that uses high frequency pulsed DC current and elec magnetic fields. The circuit that I am using calls for an earth ground on the negative side of the circuit. The issue I am having is that when I have the meter powered by the 2 prong usb supply when I operate the device I am working on I get extremely high counts from the meter. If I remove the 2 prong usb wall power supply and power the meter by the batteries I do not have this issue. Could anyone possible help me to figure out what is going on?
Whatever type of machine this is - unless you are somewhere along the setup use 50 kilo-Volt there is not even a remote chance of creating radioactivity which any Geiger counter could detect!
When you do see counts in your Geiger counter, it is because of electric disturbances. The GMC counter are NOT immune to electric noise! But the numbers are utterly meaningless.
