 Wifi Signal issues with GMC-500+
staze Posted - 12/26/2023 : 16:45:57
Hey All,
I've had a GMC-500 for several years now, and it tends to work quite well, but I've noticed over the years it's wifi connectivity is pretty poor. Frequent disconnects, low connection speed, etc.
I believe it's version 1.25 (according to "About"). It's got 2 APs that are maybe 20-30 feet (via a wall or two) away. I noticed on this thread https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=5461&SearchTerms=wifi,antenna there's talk about a hole in the PCB behind the ESP wifi antenna. So I kind of assume this is a known issue? is there any kind of workaround?
Thanks!
ullix Posted - 12/28/2023 : 02:09:09
... firmware updates don’t update the WiFi module firmware.
Indeed, they won't. The WiFi capability is introduced by an ESP8266 chip, which is pre-programmed for WiFi, likely having an imprint of ESP-12S on the silvery chip. The GMC firmware talks to it like to a modem in decade-old commands like '<AT+RST>>'. Those commands won't change in new GMC firmware!
However, it cannot be ruled out that the firmware on the ESP8266 does change over time. But this will only be seen in newly purchased devices.
In theory the firmware on the ESP8266 can also be modified, but this is not trivial, AND there have to be provisions on the circuit board of the GMC counter, which I think do not exist.
Look at the antenna of the ESP-12S, which is the wiggly copper path next to the silvery case. Does it look ok? Not much you can do.
staze Posted - 12/27/2023 : 18:21:52
Thanks for link to raspi option. Will have to consider that if I can’t get this working more reliably.
staze Posted - 12/27/2023 : 18:19:28
Request sent for new firmware. Though I believe in the past I’ve been told firmware updates don’t update the WiFi module firmware.
ihab17 Posted - 12/27/2023 : 04:19:58
Your firmware version seems outdated and the issue might be solved with the latest firmware update. You should email the support with your serial number to generate a firmware for your device
ullix Posted - 12/27/2023 : 02:39:20
My suggestion: connect it to a Raspberry Pi computer. I just posted on this in this topic: http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=10352
