 gmc-500+ not reading
rlevans Posted - 02/02/2021 : 11:27:25
I was at a uranium mine last week; I got some readings while walking around. However, when I had a substantial piece of carnotite, my gmc did not register anything while another persons "geiger" counter went wild. Is this a GMC problem or should i not expect it to react to such a hot specimen? perplexed.
Damien68 Posted - 02/04/2021 : 10:55:59
I would store it in a metal box like a sugar box, it shouldn't come out much, you can check it with your counter. and store it in a suitable place.
like said EmfDev 320 CPM is fun and not very dangerous.
EmfDev Posted - 02/04/2021 : 10:45:20
When you go to factory reset, you should leave it to "Yes" and after few seconds it will popup "Factory Reset..." then after a few more seconds it will go back to the main screen Large Font Mode with 0 CPM and will start counting. But it seems it did the trick. For the 320 CPM Piece, it seems a little high but not too high. As long as you properly store it, it shouldnt be a worry.
rlevans Posted - 02/04/2021 : 10:26:45
Now, the ambient in house cpm is 16; when I went out to the piece I started with and let it sit along side of it, it went to 320 CPM; so perhaps now its working either from the factory reset or the tube voltage increase. which do you think? and now, for a really novice question, what should I do with the 320 cpm piece and sevarl like it? what is my health risk?
rlevans Posted - 02/04/2021 : 10:09:39
I went into the tube settings and did not really see an on/off option. I did look at the tube voltages? they were at 22%; I upped then to mid 30's...? just not sure what is right, As far as the factory reset, I tried and perhaps did it, but there is no indication from the machine that anything happened...?!
EmfDev Posted - 02/02/2021 : 16:32:57
Hi rlevans, by saying 0 did you mean 0 CPM? If that is the case, there seems to be something wrong with the device and it should not ever read 0 CPM.
Have you tried to factory reset? depending on your area the device should read around 10-30 CPM with just background radiation. Please check whether the device tube 1 is turned off.
rlevans Posted - 02/02/2021 : 15:31:43
walking near the the talus piles it read as high as 8; its where I found a piece of loose material with several layers of andsersonite/ carnicite and got no reading , 0 reading when held my GQ in close proximity... a asked the guy with the still unknown geiger counter to read it and got a strong loud continuous beep and no, I asked, but I don't know the make and model of the other unit.
EmfDev Posted - 02/02/2021 : 12:00:52
Hi rlevans, what readings are you getting when you walk around and what is this persons geiger counter? What did you mean it did not register anything? Did it go higher than background reading?
