 Geiger counter not showing in map
SolarSurveyMonitor Posted - 04/11/2019 : 13:29:59
Hello
I have been sending data using Data Logger STD 5.6 but it sill not showing on map. I created new device on account, even removed leading zero on user ID refreshing page but don not worked.
GID: 16717393500
José
SolarSurveyMonitor Posted - 04/29/2019 : 09:08:44
Just a note to say that is now working well again.
Ponty Posted - 04/22/2019 : 11:45:41
Looks like you are back in business, at least I am able to submit data again :-)
EmfDev Posted - 04/22/2019 : 10:10:07
Sorry guys we are trying to fix the issues. Looks like https problem.
Ponty Posted - 04/20/2019 : 05:27:13
I confirm. My device can't send either. Please have a look at what is wrong.
Normal send fails with "WiFi Data Send Failed"
and
Test connection fails with "Link Server Failed"
GMC device has IP and is connected to the WiFi.
I seem to remember that the GMC-320+V5 won't send until it has successfully completed the Connection Test, so at the moment the problem seems to lie here...
What is the connection test it performs, can we try it out manually ?
-ANTI_PSYOP Posted - 04/20/2019 : 00:20:52
The developer is working on the website right now.
there seems to be quite a few problems with the https://www.gmcmap.com service it is working intermittently, and many of the regular geiger counters on the map, are not uploading to the service, nor am I, because I cannot send my data to the service, yesterday it was working intermittently, now there is no connection, is there s fix on the way? and when can it be expected
EmfDev Posted - 04/19/2019 : 15:59:24
SolarSurveyMonitor Posted - 04/19/2019 : 15:39:27
Still can not see. Now map is empty (likely light blue background color)
EmfDev Posted - 04/19/2019 : 11:19:10
Hi Solar, looks like website is back.
EmfDev Posted - 04/19/2019 : 10:04:26
Hmm looks like server is down. Will let support know about this. Sorry for the inconvenience.
SolarSurveyMonitor Posted - 04/19/2019 : 09:50:48
Can not check at this moment, GMCMap shows an 503 Service unavailable error.
EmfDev Posted - 04/17/2019 : 12:46:45
Hi Solar, we tried to fix the problem. Can you try again if it's working? Thanks!
EmfDev Posted - 04/12/2019 : 14:40:24
Yes your we found new data in the history but isn't on the active list. looks like.
SolarSurveyMonitor Posted - 04/11/2019 : 14:16:13
Hi Solar, we are aware of this problem. We are currently looking for the problem and trying to fix it. Looks like the data is being sent to the wrong database.
But can you still see your history data?
Yes, data is listed correctly, however there is no pin on map.
EmfDev Posted - 04/11/2019 : 14:10:40
Generated in 1.22 sec. Snitz's Forums 2000
