 GQ Geiger Counter Data Logger V5.22
Nuclear-Spud Posted - 08/28/2012 : 04:19:35
Recently downloaded and purchased a key for GQ Geiger Counter Data Logger V5.22, I am having a couple of problems, I am trying to set up and get working the "GQ Geiger Counter Data Logger web server PHP by Bob Holmes"
Problem with GQ GMCounter PRO
I have entered the details in the Settings - Other page Click OK but when ever I make a change in any field and use the Cancel button all fields are set to default, this also happens when I quit the application and restart it, also happens for the FTP Settings page
I am using Windows 7 Pro.
I have a question relating to the web server PHP I will post that under the other thread and keep this for the software.
Nuclear-Spud Posted - 09/21/2012 : 20:19:29
Still having a few problems with Geiger Counter Pro Data Logger,
I have a copy on my server running and saving a .CSV and _R.CSV file to a local folder, after 24 or so hours the following error stopped the programme "an unnamed file was not found" I have the following setting selected, Auto Save, Fixed File Name and interval of 2 minutes.
I have OK'd the error and reconfirmed the file path settings > other, software is confirming saving of file again but there is no data in them.
Does the software do anything after 24hr with the output log file, my file resets and a new blank one is started.
I am not using FTP to upload.
Is anyone else having the problem in my earlier post with settings not being saved whe the programme exits and is restarted.
Cheers
Jason
Nuclear-Spud Posted - 09/04/2012 : 06:23:23
Hi again,
I am still having the problem with the settings not being saved when clicking cancel or exiting and restarting the software, is anyone else having this problem, I have tried on Win7 as Administrator and on WinXP bot with the same results.
I also wanted to know if both file are supposed to be uploaded by FTP when the option of CSV & Reverse is selected as I am using the PHP Graphs and they require the reverse data file, I am uploading this with another application at this stage.
Could there be an option in future releases to allow user selection of say 2-4 files to be uploaded via FTP.
ZLM Posted - 09/02/2012 : 20:46:06
Not sure why your setting not be saved. Try run the software as administrator.
All setting should be able to be saved.
