 GMC-300E driver needed
gmc300edriverneeded
Japan
Posted - 12/27/2013 :  10:22:12  Show Profile  Reply with Quote
please provide lync so I can download the software.
I have looked and downloaded several but they don't work. I need the GMC-300E driver. The cd received did not work. Please provide the lync that takes me directly to the actual ".exe" for the abovementioned device. thank you!
gmc300edriverneeded
Japan
Posted - 12/27/2013 :  10:50:16  Show Profile  Reply with Quote
the cd I received is blank when I checked he properties.
x
Posted - 12/27/2013 :  12:26:32  Show Profile  Reply with Quote
All software and driver you can download from:
The USB Driver:
http://www.gqelectronicsllc.com/downloads/download.asp?DownloadID=60
The Data Viewer:
http://www.gqelectronicsllc.com/downloads/download.asp?DownloadID=61
gmc300edriverneeded
Japan
Posted - 12/29/2013 :  14:45:06  Show Profile  Reply with Quote
thank you for the links. i've installed, uninstalled, reinstalled and still no luck. the unit seems to work fine, but cannot communicate with the software. a compatability issue with windows7. is there anything else i can try? thanks.
x
Posted - 12/30/2013 :  20:57:43  Show Profile  Reply with Quote
The USB driver has no compatibility problem with Windows 7.
From your Windows device manager, confrim the USB driver is loaded correctly when the device is connected.
See:
http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=3796
bignumbas
Australia
Posted - 01/02/2014 :  14:10:41  Show Profile  Reply with Quote
Have you checked the comm port number that the USB software sets up when you plug in the unit? The software needs to be set to the same comm port. I find that it is not always the same port number used each time I plug in.
