I have a GMC-300 with the software GQ GMC data viewer R 1.30 and the prolific USB gets com port 16 assigned. The software doesn't go that far (maximum com 12).
I am experiencing the same issue. I've opened the Prolific USB-to-Serial Comm Port in device manager but see no way to change the port number. Despite being logged on as an admin I'm told I need registry write permissions when I click the 'advanced' button in properties. Do I need to click 'advanced' as well as 'properties' to change port number? Will you please describe how that can be done. ZLM? - Of course, a better solution would be to make the software compatible with Windows 7 and above. Here is the Device Manager view. I don't see anything identified as Prolific. Can you please help me identify it in this view? Image Insert: 39.86 KB In Control Panel | Hardware and Sound | Devices and Printers - the Prolific adapter is shown. When I right click it this is the result. But I see no way of changing the port number. Can you please tell me how to accomplish that?
Need help with setup. Windows 7 Driver version 3.4.25.218 Under the device manager Ports (COM & LPT)I can see the Prolific USB-to-Serial Comm Port (COM11). There is no device listed under Universal Serial Bus controllers. In the data viewer when I go to setting to change the serial port to com11, I keep getting the error (Com port open error). I have tried changing port setting to match the driver... rate, parity, etc. and still the same error.
I installed Re 2.01 and ran the autoscan. The data viewer software was unable to open any port. I checked window7 drivers for com ports and the driver is still listed on com11. Any other suggestions?
COM port 1 open failed. COM port 2 open failed. COM port 3 open failed. COM port 4 open failed. COM port 5 open failed. COM port 6 open failed. COM port 7 open failed. COM port 8 open failed. COM port 9 open failed. COM port 10 open failed. COM port 11 open failed. COM port 12 open failed. COM port 13 open failed. COM port 14 open failed. COM port 15 open failed. COM port 16 open failed. COM port 17 open failed. COM port 18 open failed. COM port 19 open failed. COM port 20 open failed. COM port 21 open failed. COM port 22 open failed. COM port 23 open failed. COM port 24 open failed. COM port 25 open failed. COM port 26 open failed. COM port 27 open failed. COM port 28 open failed. COM port 29 open failed. COM port 30 open failed. COM port 31 open failed. COM port 32 open failed. GQ Geiger Counter not detected, please try again.
