 GMC-320 Stopped Powering On
dlp003 Posted - 11/09/2017 : 08:45:31
Unit does not work. Battery replaced.
EmfDev Posted - 01/19/2018 : 13:05:45
Hi psoubourou,
It seems like the configuration data is corrupted for some reason. Just keep it rebooting for at most a day and it will eventually fix itself. After working, you need to do a factory reset from the menu.
If still doesn't work after 24 hours of rebooting, then contact support so you can send it back for warranty.
psoubourou Posted - 01/19/2018 : 03:05:23
I have an issue this morning : I start the GMC-320 as usual, get the invite screen backlit :
GMC-320
(+V4)
But the device never actually starts past the invite. I see it flicker after 3s and then the invite screen appears again, and it does this indefinitely. I never get the menus. But I hear the clicks of the GM counting.
I've tried disconnecting reconnecting the device's battery, plugging unplugging the cord, but the problem remains.
Thanks for your help.
ZLM Posted - 11/15/2017 : 15:21:04
Use USB cable to power. If this way work, then the problem is battery contacting.
