 New user need help
lightlee Posted - 03/22/2013 : 01:18:46
GMC-300 what is the model of geiger.Can detection x rays, the MIN/MAX radiation sensitivity howmuch?
ZLM Posted - 05/02/2013 : 14:44:56
Battery problem? You can change to a good 9V rechageable battery. The battery is NiMH 9V with 8.4V norminal voltage.
lightlee Posted - 05/02/2013 : 04:41:17
Why is so inefficient? Shut down inefficient, too? Recharge every day
ZLM Posted - 04/29/2013 : 13:34:37
OK. What is the maximume value you got?
The backgroud reading has no fixed value. It always change within a range. It normally in 0.02uSv/h-0.2uSv/h.
If you got 5uSv/h backgroud,then it is high radiation background.
lightlee Posted - 04/28/2013 : 04:44:21
Step value is too small, to show 5 uSv/h to slowly growth.the actual radiation is 5uSv/h,Growth of 5uSv/h take a few minutes.
ZLM Posted - 04/27/2013 : 17:55:48
From "5uSv/h, slowly increased to 5.not once become 5." ??
What is the unit on your "increased to 5."? increaded to 5.0uSv/h ?
lightlee Posted - 04/27/2013 : 07:36:15
For example, the actual radiation is 5uSv/h, slowly increased to 5.not once become 5.When there is no radiation, is slowly reduced to background radiation value
ZLM Posted - 04/26/2013 : 13:04:51
What do you means by "increase slowly"?
What is your back ground rading minimume to maximume? does it consistent over the time?
lightlee Posted - 04/25/2013 : 06:09:59
Can't rise to the actual radiation? It will increase slowly?
ZLM Posted - 04/24/2013 : 22:34:18
There is a background radiation reading always.
lightlee Posted - 04/22/2013 : 05:49:54
I'm a Chinese customers, why my GMC - 300 in radiation displayed when radiation dose is increased a little bit? When no radiation is also a little to reduce
ZLM Posted - 03/29/2013 : 00:35:27
It is M4011 tube.
lightlee Posted - 03/27/2013 : 22:54:22
Thank you very much.Can you tell me, GMC-300 use what type of
geiger counter?
ZLM Posted - 03/27/2013 : 22:04:35
As I know the GMC-300 is on pre-order now. All orders should be shipped in next week. Please write email to support@gqelectronicsllc.com for your particular order status.
lightlee Posted - 03/25/2013 : 01:01:29
I bought on ebay GMC why not delivery?
boss?
ZLM Posted - 03/24/2013 : 09:44:37
yes. It detects X Ray. From the description, the sensitivity to Gamma Radiation: 0.1~1 MeV
