 how to run my GMC200 and GMC concurrently?
bifferidge Posted - 02/04/2013 : 10:25:11
For some reason I cannot run both at the same time. Any tips pls?
ZLM Posted - 02/15/2013 : 20:30:48
You can use GMC-200 with USB connection at same time with GMC-300. As long as they are on different comport, then you can run the two copies of the software at same time.
bifferidge Posted - 02/15/2013 : 10:06:44
MEANT to mention: Basically only the GMC300 software works. The GMC200 audio software does nothing with my GMC200 plugged in via audio input. Help?! :-)
bifferidge Posted - 02/15/2013 : 10:04:41
there is different software suplied with both. One uses the USB/COM3 (the GMC300) and my GMC200 uses the audio output. Any suggestions? Win7, with sub-par amateur PC and software skills!
ZLM Posted - 02/04/2013 : 12:03:04
If they are using same software, then the software only can communicate with one of them.
