 Quickly explain EF
n8xyn
Posted - 01/01/2019 :  12:54:44  Show Profile  Reply with Quote
EMF in my understanding is a fluctuating magnetic field and my home is acceptable as for as that goes but EF is high what does EF reflect?
Jim Whitaker
Edited by - n8xyn on 01/01/2019 12:55:46
Posted - 01/14/2019 :  15:09:36  Show Profile  Reply with Quote
Electric fields mostly from power lines.
Bill D.
Posted - 08/13/2019 :  15:28:52  Show Profile  Reply with Quote
Household current is 120V, yet I pick up EF readings up to 1500 V/m near outlets and breaker boxes. How is that possible?
Edited by - Bill D. on 08/13/2019 15:29:57
Posted - 08/13/2019 :  15:48:50  Show Profile  Reply with Quote
Those two are different things. 120V is the voltage of the outlet and has reference to its ground that can provide current for devices. Electric field is the field around charges that can cause force to there charges.
Bill D.
Posted - 08/13/2019 :  19:38:34  Show Profile  Reply with Quote
Yes, I see the difference. But it's hard to comprehend how such high voltages are generated in the field. Is it like a feedback loop?: Current creates an oscillating magnetic field, this field creates current which in turn creates a magnetic field, etc.
Posted - 08/14/2019 :  09:56:24  Show Profile  Reply with Quote
Could be. It could also be from static around it. Those two are different things. Like you can generate few thousand EF from the carpet. It doesn't even have voltage.
Bill D.
Posted - 08/14/2019 :  12:44:12  Show Profile  Reply with Quote
In searching for an answer I came across what is called the near-field effect of antennas (since a power line is a low freq antenna): "Very close to the antenna, in the reactive region, energy of a certain amount, if not absorbed by a receiver, is held back and is stored very near the antenna surface. This energy is carried back and forth from the antenna to the reactive near field by electromagnetic radiation of the type that slowly changes electrostatic and magnetostatic effects..." Wikipedia https://en.wikipedia.org/wiki/Near_and_far_field
There are diagrams showing these regions.
Posted - 08/14/2019 :  13:07:25  Show Profile  Reply with Quote
Could be, but these are for antennas.
Bill D.
Posted - 08/14/2019 :  19:37:19  Show Profile  Reply with Quote
Finally, near some outlets and breaker boxes I get readings approaching 2000 V/m. But the specs indicate that the 390 has a range of only 0-1000 V/m. Apparently the scale extends beyond 1000 V/m or does it lose accuracy past that point?
Edited by - Bill D. on 08/15/2019 05:30:30
Posted - 08/15/2019 :  09:04:55  Show Profile  Reply with Quote
It's a little less accurate above 1000 range.
