 GQ Data Viewer Bugs and Requested Features
ffs
Posted - 03/24/2012 :  03:29:50  Show Profile  Reply with Quote
GMC-300 2.11 and Data Viewer 1.02
Bugs:
- The realtime monitoring culls all data after running over 24 hours and starts recording new data using the previous data's timestamps.
- mR/h column in data exported to html always reads 0...
- The software quits/crashes without warning randomly. I don't know how to reproduce this one, but it happens within a few hours of running realtime monitoring.
Requested Features:
- Being able to note the location in realtime monitoring would be nice. Inserting a custom heading for the exported csv and html spreadsheets would be handy as well.
- A uSv/hr column in the exported html.
- Automated saving of realtime monitoring data, either by interval or setting the time or both. I'd like to be able to save the last 24 hours of data every day at midnight for example.
- Saving as csv and html simultaneously. Saving as all formats simultaneously. Maybe a set of checkboxes to choose multiple formats instead of the drop down list, especially for the proposed automated saving of real time data.
ffs
Posted - 03/24/2012 :  03:44:36  Show Profile  Reply with Quote
I just realized you can choose to save as all formats. However the feature doesn't work and when selected results in no saving of any data in any format, so chalk it up as another bug.
Posted - 03/24/2012 :  19:01:14  Show Profile  Reply with Quote
Tested saving in both .CSV and .RBN files at once and it works fine.
The software stores data for 24hours and then restart again after 24 hours. But it should save the last 24 hours data automatically before it restart. I will check this feature after 24 hours. If it does not save the data, then it must be a software bug and it must be fixed soon.
ffs
Posted - 03/30/2012 :  15:06:28  Show Profile  Reply with Quote
Data Viewer 1.10
Bugs
-Real time data saved to HTML always reads 0 in mR/h column
ffs
Posted - 03/31/2012 :  16:57:30  Show Profile  Reply with Quote
v1.10
-Data saved as CSV also always reads 0 under mR/h
-Data saved after 24 hours in real time logging still uses timestamps from first 24 hours.
-Auto save failed:
"2012-03-31 09:52:50:
File error:C:\gmc300 data\C:\gmc300 data\20120331_09_52_50.rbn
File error:C:\gmc300 data\C:\gmc300 data\20120331_09_52_50.csv
24 hours data auto saved."
Posted - 04/01/2012 :  07:59:41  Show Profile  Reply with Quote
"uses timestamps from first 24 hours"? Do you mean the elapsed time?
ffs
Posted - 04/01/2012 :  10:13:56  Show Profile  Reply with Quote
Data saved after 24 hours has the same date and time as the data from the first 24 hours.
First 24 hours:
h**p://home.comcast.net/~f_f_s/gmc300/20120331_09_41_13.htm
Data saved after 24 hours; the data viewer is recording new readings using the date and time from the first 24 hours:
h**p://home.comcast.net/~f_f_s/gmc300/20120331_19_43_58.htm
Posted - 04/02/2012 :  23:43:37  Show Profile  Reply with Quote
Try Re1.12.
The mR/h field is removed since there is no calibration data in current version.
Posted - 04/03/2012 :  07:40:06  Show Profile  Reply with Quote
sorry, it is Re1.13
Try Re1.13.
ffs
Posted - 04/03/2012 :  10:48:12  Show Profile  Reply with Quote
1.13
Auto saving works, thanks. However, it auto saves every 10 seconds now :/
"2012-04-03 13:05:00:
Saved:C:\20120403_13_05_00.csv
2012-04-03 13:05:11:
Saved:C:\20120403_13_05_11.rbn
Saved:C:\20120403_13_05_11.csv
2012-04-03 13:05:23:
Saved:C:\20120403_13_05_23.rbn
Saved:C:\20120403_13_05_23.csv
2012-04-03 13:05:34:
Saved:C:\20120403_13_05_34.rbn
Saved:C:\20120403_13_05_34.csv
Heartbeat stopped.."
Also, the software doesn't append the .bin extension to data downloaded from the gmc-300's memory.
Auto saving as html as well as rbn and csv would be greatly appreciated. Thanks again for the speedy fixes/updates!
Posted - 04/03/2012 :  12:15:32  Show Profile  Reply with Quote
It should add .bin extendion. No problem found.
try Re1.14.
Auto save .html added.
