 Charging and voltage level question for theGMC300
BlueSky
Posted - 01/20/2012 :  17:16:13  Show Profile  Reply with Quote
I have the wall adapter plugged in, both red and green lights are lit on that, will the red clear once charged?
What should I adjust the voltage level for if say I want to take radiation level readings on my car that I drive through steam from a nuclear power plant?
I really do drive through the steam when the wind blows road side
Thanks guys
Edited by - BlueSky on 01/20/2012 18:30:41
Posted - 01/20/2012 :  20:52:59  Show Profile  Reply with Quote
The green LED indicates the connection is good between wall adapter and the GMC-300. The red LED shows the adapter is working.
The only battery status is the battery icon on the GMC-300 screen. See GMC-300 user guide. If the battery is fully charged, the batery icon will stop animation and stay in a solid black color.
You do not need to adjust anything when you measuring radiation. You just need to see if the CPM reading changes.
A stable reading should take a few minutes since the radiation level is calculated based on the Count Per Minute(CPM) value.
If you in a car and drive through a nuclear power plant less than a minute, then you may not be able see much changes. You may leave the Geiger Counter at the testing spot for a few minuts and then see if the CPM changed.
BlueSky
Posted - 01/20/2012 :  21:11:37  Show Profile  Reply with Quote
Thank you sir
Odiez1
Posted - 01/23/2012 :  17:38:37  Show Profile  Reply with Quote
I sincerely hope the plant isn't letting anything out with the steam from the stack. Assuming that's one of the large flared top, Simpson's TV show like, evaporation towers. Those shouldn't even carry the heavy water loop through them. The steam should be from the pond/lake/river/ocean water they use as the final heat exchanging, and not be radioactive.
If it's steam from any other towers on a Nuc plant, looking more like an oil refinery tower, then I'd be really worried.
My 2c.
-Odie
BlueSky
Posted - 01/24/2012 :  07:57:49  Show Profile  Reply with Quote
Cool, It is large flared top. Just glad were clean
chris
Posted - 03/03/2012 :  05:09:05  Show Profile  Reply with Quote
ZLM, in this post you refer to a "GMC-300 user guide".
where can I find one?
nothing came with the GQ GMC-300 I bought. no quick start guide either.
Posted - 03/03/2012 :  13:08:13  Show Profile  Reply with Quote
Now it is in the download page:
chris
Posted - 03/03/2012 :  21:00:29  Show Profile  Reply with Quote
Thanks! found it
vilagan
Australia
Posted - 03/15/2012 :  02:27:17  Show Profile  Reply with Quote
Hey ZLM, is the GMC-300 being charged while connected to the USB port of the computer? I note that the charger adapters for both AC and DC output the same 5volts into the rechargeable battery.... reason I asked is there might be no need to bring a charger along if my netbook/laptop is always handy to charge it anyway.....
Posted - 03/15/2012 :  09:39:28  Show Profile  Reply with Quote
Yes. While the GMC-300 connected to the computer USB port, the batter is charged at same time.
The wall charger and the car charger are not needed if you connect the GMC-300 to a computer USB port.
vilagan
Australia
Posted - 03/15/2012 :  15:54:43  Show Profile  Reply with Quote
Thanks - handy to know.... very happy with my GMC-300!! ,,, and thanks for the swift response...
