 Silver Colored Fixture Screws
pgammell@ieee.org
Posted - 09/03/2015 :  18:50:34  Show Profile  Reply with Quote
are the "silver colored fixture screws" the 3 phillips head screws on the bottom that are secured with a triangular section of wire tie that must be broken to turn them? What is the problem if I do not remove them?
PMG
Posted - 09/04/2015 :  10:41:03  Show Profile  Reply with Quote
Those screws MUST be removed before using. Those are for transportation only. Keep the screws in a safe place and use it for long distance transportation. If you do not remove it, then it makes loud noise and may damage the air pumper.
18.36 KB
