 There is no access to EMF-390 v2 on PC Win32
ekaterinamalysh
Russia
Posted - 03/24/2025 :  05:31:00  Show Profile  Reply with Quote
Hi. I have installed the CH341SER driver, but the pc still does not see the EMF-390v2. What could be the problem and how to solve it?
EkaterinaM
Posted - 03/24/2025 :  12:45:57  Show Profile  Reply with Quote
Check device manager and find USB-Serial CH340 under Ports and check the port number.
GraceSamuel
Posted - 03/25/2025 :  02:05:37  Show Profile  Reply with Quote
Thanks! I’ll reinstall the driver and check the connections.
Edited by - GraceSamuel on 03/25/2025 02:06:45
Posted - 03/25/2025 :  09:26:16  Show Profile  Reply with Quote
usually, win10/11 does not need to install the driver.
Liya
Hong Kong
Posted - 01/04/2026 :  22:54:02  Show Profile  Reply with Quote
Please try the following two steps first:
Replace the USB cable: Make sure you are using a cable that supports data transfer, not just a charging cable (many standard cables may only be for charging).
Check Device Manager: After connecting the device, check if "CH340" appears under "Ports" in "Device Manager," or if there is an unknown device with an exclamation mark.
