 GQ GMC-800 error bought on Amazon Belgium
mikecbb18
Posted - 12/19/2025 :  14:50:30  Show Profile  Reply with Quote
The Geiger counter I bought from Amazon Belgium(received on 18,Dec,2025), a GQ GMC-800, shows a CPM to #956;sv/h ratio of 100 on its display, instead of around 154.
For example, In the Dose Rate Options of the screen,0.14 #956;sv/h = 14 CPM. However, after connecting the Geiger counter to my computer via USB, the downloaded CSV file did not have this incorrect conversion relationship:
Date Time Type uSv/h CPM
2025/12/9 11:04 Every Second 0.078 12
2025/12/9 11:05 Every Second 0.091 14
2025/12/9 11:06 Every Second 0.123 19
2025/12/9 11:07 Every Second 0.123 19
2025/12/9 11:08 Every Second 0.104 16
2025/12/9 11:09 Every Second 0.097 15
2025/12/9 11:10 Every Second 0.045 7
2025/12/18 4:30 Every Second 0.117 18
2025/12/18 4:31 Every Second 0.091 14
2025/12/18 4:32 Every Second 0.058 9
I then bought the same model from Amazon Belgium and found that it had the same problem.
So, my question is: 1.In the European version of the GMC-800, is the relationship between CPM and uSv/h on the Geiger counter instrument display incorrect? Should I actually be looking at the data exported from the computer?
2. Or is it that the European version of the GMC-800 is not calibrated and therefore unusable?
Posted - 12/22/2025 :  10:12:21  Show Profile  Reply with Quote
This is the updated calibration version of the gmc-800.
mikecbb18
Posted - 12/23/2025 :  05:25:53  Show Profile  Reply with Quote
I understand. Do you mean I can use this Geiger counter gmc-800 normally (CPM to uSv/h ratio is around 100)?
