 First battery Ñharge EMF-390
Green Peace
Ukraine
Posted - 04/05/2021 :  08:44:55  Show Profile  Reply with Quote
Hi :)
Please tell me how many Hours it takes to make the First charge of the battery in the EMF-390 after the purchase, before using the device ?
Will it need to be charged for 16 hours straight, like GP Ni-MH batteries ?
Thank you :) for training ...
0.0006 - 0.0128 mcW/cm2 = 0.006 - 0.128 mW/m2 = 48 mV/m - 220 mV/m :
Fatigue, depressive tendency, sleeping disorders, concentration difficulties, cardio- vascular problems reported with exposure to GSM 900/1800 MHz cell phone signal at base station level exposures.
Oberfeld, 2004
www.bioinitiative.org/wp-content/uploads/pdfs/BioInitiativeReport-RF-Color-Charts.pdf
Edited by - Green Peace on 04/05/2021 21:25:12
Posted - 04/06/2021 :  10:32:50  Show Profile  Reply with Quote
Hi Green Peace, probably around few hours/minutes. It usually comes almost fully charged but occasionally it comes half the charge.
Green Peace
Ukraine
Posted - 04/06/2021 :  23:45:21  Show Profile  Reply with Quote
Thank you :) EmfDev !
The Meter has already received a 100 % battery charge, more than 4 Volts of charge.
The Meter works perfectly and shows detailed information about the surrounding EMF levels
Oberfeld, 2004
kbfifi
Posted - 02/13/2024 :  06:44:57  Show Profile  Reply with Quote
Hi, received my EMC-390 yesterday. Is still charging since then! (24h as of now) Meaning: It shows" "Charging... 100%" from the start. The documentation states that the charging is complted when the battery icon stops flashing. It is still flashing. Reading this topic charging can be slow but it is to be expected that new models are mostly almost fully charged. Any suggestions?
Edited by - kbfifi on 02/13/2024 06:46:04
Posted - 02/14/2024 :  11:09:40  Show Profile  Reply with Quote
Hi kbfifi, this may be because the backlight level is too high. I think 100% should be around the 4.1V so it is ok remove it from charging.
kbfifi
Posted - 02/16/2024 :  04:28:03  Show Profile  Reply with Quote
Hi EmfDev, thanks for thinking with me! I've used the meter for some days now. Works just fine. Just recharged it back to 100% in the hope it was an initial behaviour. But it still keeps showing animating battery icon. So I guess it may be because of an FW update or the manual not being accurate. I consider the 100% info as leading and ignore the the animating icon.
Tony
Posted - 02/18/2025 :  07:05:06  Show Profile  Reply with Quote
Hi, I recently purchased the GQ 390, it arrived with a 100% battery charge, so I used it straight away for a few days, then when the battery was almost at the end of its charge, I recharged it for the first time, after a few hours, I read on the display that the battery was 100% charged but the battery icon is still moving, my question is: when is the charge complete when it says 100% even if the icon is still moving, or do you have to leave it charging until the icon and the barrier signal fill up and stop? Thanks
ok
Posted - 02/18/2025 :  12:00:00  Show Profile  Reply with Quote
You can stop charging at 100%. Ignore the animation since the backlight is also consuming power so it thinks it still needs to charge.
