 History data doesn't show on the map
daviddrake Posted - 11/01/2022 : 09:52:14
I have the Data Viewer V2.63. I verified my GMC-300E. I set up for the map data sending every 5 minutes. I don't see any history data on the map. I'm sure I'm doing something wrong, but I need advice. Instantaneous data does come through.
EmfDev Posted - 11/15/2022 : 15:41:16
hi daviddrake, have you solved the issue?
daviddrake Posted - 11/09/2022 : 14:21:03
Forgive the confusion. I do see an account ID 05555 and a GC ID 38410471363 and the verify works. I don't see a pin field. I'm clearly missing something here.
I did try the manual test and it came up with GCN advice on data submittals, but no obvious pin.
I think we're close...
EmfDev Posted - 11/08/2022 : 16:07:31
manually submit those to a browser without the type=VWR2.63 to let the pin appear first.
Just tried it. Hopefully you can see your pin now.
daviddrake Posted - 11/04/2022 : 11:28:04
Here is more of the log: (showing some type of errors)
e:2022-11-04 11:55:00
h**p://www.gmcmap.com/log2.asp?AID=05555&GID=38410471363&CPM=45&ACPM=29.83&uSV=0.292500&type=VWR2.63
Data submited to server.
<!-- sendmail.asp-->
OK.ERR0
Report time:2022-11-04 12:00:00
h**p://www.gmcmap.com/log2.asp?AID=05555&GID=38410471363&CPM=22&ACPM=29.83&uSV=0.143000&type=VWR2.63
OK.ERR0
Report time:2022-11-04 12:05:00
OK.ERR0
Report time:2022-11-04 12:10:00
ttp://www.gmcmap.com/log2.asp?AID=05555&GID=38410471363&CPM=24&ACPM=29.83&uSV=0.156000&type=VWR2.63
OK.ERR0
Report time:2022-11-04 12:15:00
h**p://www.gmcmap.com/log2.asp?AID=05555&GID=38410471363&CPM=33&ACPM=29.83&uSV=0.214500&type=VWR2.63
OK.ERR0
Report time:2022-11-04 12:20:00
h**p://www.gmcmap.com/log2.asp?AID=05555&GID=38410471363&CPM=41&ACPM=29.83&uSV=0.266500&type=VWR2.63
OK.ERR0
Report time:2022-11-04 12:25:00
daviddrake Posted - 11/04/2022 : 10:45:20
The log file does show the data was sent to the log2.asp Still no evident history displayed.
daviddrake Posted - 11/03/2022 : 14:19:35
The www.gmcmap.com reference is there. No obvious place to put log2.asp
I issue the verify request which succeeds.
EmfDev Posted - 11/03/2022 : 09:25:51
Hi daviddrake, can you check your data viewer software website and url? It should be www.gmcmap.com and log2.asp.
