 Vertical Mode RF causes no display
Joff Posted - 05/13/2021 : 04:06:15
Hi
When I switch to Vertical Mode and then choose the S3 button I can toggle between EMF/EF and RF. When I choose RF there is no more display other than the menu. I need to choose EMF/EF to get a display again.
I am using the GQ-EMF390 V2 revision 3.65
Sanast Posted - 05/27/2021 : 09:34:38
I already sent the serial to support and to you now via forum email
EmfDev Posted - 05/27/2021 : 07:56:21
Hi Sanast, please send/email me your device serial number under Main Menu -> About -> Serial# then I will create the firmware for you.
Sanast Posted - 05/26/2021 : 22:07:09
I have the same problem. Vertical RF mode is not working. How do i update the firmware?
Joff Posted - 05/14/2021 : 11:25:46
Thank you - all sorted with the firmware update!
EmfDev Posted - 05/14/2021 : 09:06:05
Got it!
Joff Posted - 05/13/2021 : 23:18:17
I sent the mail via the Forum form and now also to the Support email address.
EmfDev Posted - 05/13/2021 : 12:16:54
I dont think I received your email yet.
Joff Posted - 05/13/2021 : 10:42:38
I sent it through - thanks.
Hi Joff, can you please email me your serial number? I will send you a firmware update to get the RF display. Thanks!
EmfDev Posted - 05/13/2021 : 10:21:56
