 GMCMAP on my website
Gallaxial Posted - 08/11/2020 : 09:07:21
I am on the GMCMAP , Can i have the Website ( h**p://www.gmcmap.com/index.asp )
on my own Website, IN REAL TIME
i am not a programmer but can copy the code ? ( its not realtime ), just copy /paste
ALso i Want to put ON my Web Site the Screen of the GQ GMC DATA LOGGUER PRO -last 60 minutes graph-
the only Way i Did it its to Snapshot the Screen with the FSCAPTURE every minutes
I have the GMC-320Re 5.54
Old software Available on the Website Not Work For me!
gqnewuser Posted - 01/24/2021 : 06:06:13
THIS ISSUE IS SOLVED: https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=8780&SearchTerms=website
gqnewuser Posted - 01/22/2021 : 12:42:06
Yes, I have gotten the above two links to work. But is there any feature where it would simply display the data, perhaps with a nice graph? If not with graph, then maybe display without the { } and " characters, just something that could be displayed on a single web page. Such as follows:
Time: 2021-01-21 14:35:45
CPM: 20
ACPM: 16.33
uSv: 0.13
Instead of the currently displayed
{"time": "2021-01-21 14:35:45", "CPM": "20", "ACPM": "16.33", "uSv": "0.13"}
Thank you.
EmfDev Posted - 09/30/2020 : 16:59:04
Try this method from this thread if this is what you're looking for.
https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=6765&SearchTerms=pull
to pull history data for graphing:
https://www.gmcmap.com/gmc-plain-data.asp?Param_ID=YOUR_GEIGER_COUNTER_ID&timezone=TIME_ZONE_OFFSET
to pulls single latest data:
https://www.gmcmap.com/historyData-plain.asp?Param_ID=YOUR_GEIGER_COUNTER_ID&timezone=TIME_ZONE_OFFSET
GBG12 Posted - 09/30/2020 : 16:27:10
Putting a near-real-time graph of a sensor on your own website is easily doable from a different radiation map site, Radmon.org. Once you set up your GQ detector to submit to that site, the server allows retrieval of the same graphs for local web page display.
EmfDev Posted - 08/11/2020 : 10:39:08
Hi Gallaxial, according to our dev, it wont work because it needs the database to pull data from.
