 GQ-GMC Models With Only Pulse Data Out
GeoMan Posted - 03/29/2020 : 10:21:43
I have a GMC-320+ but I don't think I can use it with Radiation Network Software which seems to require only pulses from the output port of the counter.
What older model GQ's have only pulses on the output port?
EmfDev Posted - 03/30/2020 : 15:29:27
On the Radiation Software Network map? No I have not.
GeoMan Posted - 03/30/2020 : 12:28:52
I think it does need analog pulse, so I listened at the output jack and there are pulses in the headphones that correspond to the counts.
The 320+ will probably work.
Have you used the GQ software to map your location data on their map?
EmfDev Posted - 03/30/2020 : 09:45:54
Does that software need analog input?
GeoMan Posted - 03/30/2020 : 09:28:54
I thought that the 320+ data jack also had at least a header sent along with the pulse data?
Wouldn't that confuse the Radio Network Software with false counts?
EmfDev Posted - 03/30/2020 : 08:53:01
Hi GeoMan, the 320+ has an audio jack for analog output, you can use that one.
GeoMan Posted - 03/29/2020 : 12:27:07
I also have an Images SI GCA-07W with a headphone output port. I think I will use that instead of trying to find an older GQ unit with only a pulse output.
