 ACPM going haywire
mnrad Posted - 06/25/2019 : 16:48:38
Hi All,
The average Counts per minute at my station started going haywire sometime yesterday - was at 17.21 then skyrocketed without a spike in actual CPM data. Now its moving around between 2 and thousands of CPM. Any idea what is going on?
19   L A T E S T    R E P L I E S    (Newest First)
EmfDev Posted - 02/03/2020 : 10:50:31
Sorry just replied your emails.
imbroglio Posted - 01/31/2020 : 20:55:26
Hi imbroglio, you can reply to my email.
I have sent you 2 emails with my serial number, one on the 24th and another yesterday, but still no updated firmware.
EmfDev Posted - 01/23/2020 : 15:22:16
imbroglio Posted - 01/23/2020 : 14:23:53
I have a GMC-320+ V5 that has this 45 day bug. Can I also get a firmware update?
tarrant1969 Posted - 12/07/2019 : 17:29:28
Im Having the same problem with my 320V5 can i get the update as well?
EmfDev Posted - 11/01/2019 : 12:43:38
mnrad, I send you an email.
mnrad Posted - 11/01/2019 : 11:26:27
Hi JJT. I sent you an email.
Hello emfdev, I also need a firmware upgrade. My serial number is ****
Thanks,
MNRAD
EmfDev Posted - 10/09/2019 : 11:53:07
JJT Posted - 10/09/2019 : 10:02:26
I do believe that I need a firmware upgrade for my GMC-320+ Rev. 4.2 serial #XXXXXXXXXIs that something you can email me?
Hello, a new firmware has been released for a fix on this issue. If there's still a problem after 45 days please let me know.
Also, please email me with your serial number for a firmware upgrade. Thanks.
EmfDev Posted - 09/09/2019 : 14:07:14
EmfDev Posted - 09/03/2019 : 09:56:40
Looks like the problem is in the number of total minutes. 60*24*45 = ~65k. The GMC300/320 units are only 16 bits an can't handle those number I think so it's going to roll back to 0. We will check the code.
MeasureMan Posted - 08/31/2019 : 06:33:51
I think I have the same issue, have a look at h**p://www.gmcmap.com/historyData.asp?Param_ID=84088394441 I Have a GMC320+V5 Re 5.51. Is there a fix available?
EmfDev Posted - 06/26/2019 : 16:10:09
Yeah looks like there's still a but that isn't fixed. It has been reported before but it's hard to produce because it happens every 45 days that the ACPM just spikes.
There's no way to fix the ACPM unless you restart the unit.
mnrad Posted - 06/26/2019 : 15:41:21
Yes, it is ~ day 45 since I've started submitting data. Hopefully the ACPM values will normalize soon - its still up at ~500CPM average while my data is showing 10-30CPM.
EmfDev Posted - 06/26/2019 : 14:44:32
Looks like its a bug. There's a bug where every 45 days the CPM spiked.
Can you check if elapsed day is ~45.
mnrad Posted - 06/26/2019 : 14:08:34
Yes, it is also high. Checked in text and csv. Max is ~650CPM. But I have not had any spikes in actual CPM values and the ACPM values make no sense.
EmfDev Posted - 06/26/2019 : 13:21:58
Have you checked your ACPM in text mode? is it also high? And what's your max CPM?
mnrad Posted - 06/26/2019 : 12:57:52
GMC-320 Plus
Just direct to the server over WiFi
Hi mnrad, what software are you using on which GMC model?
EmfDev Posted - 06/26/2019 : 09:24:33
