 Pull realtime count
staze Posted - 03/20/2019 : 18:45:52
Just curious if there's an endpoint where I can pull a current count (don't need historical) in json or something similar?
Basically identical to www.gmcmap.com/gmc-plain-data.asp?Param_ID=YOUR_GEIGER_COUNTER_ID&timezone=TIME_ZONE
Only presenting a single result rather than 500. Maybe just altering that gmc-plain-data.asp to accept a "number" variable and that could be set to 1.
Thanks!
staze Posted - 03/27/2019 : 18:04:17
Hi @hiro,
That's great! Thanks!!!
hiro Posted - 03/27/2019 : 12:24:18
Hi staze, please try the following link:
www.gmcmap.com/historyData-plain.asp?Param_ID=YOUR_GEIGER_COUNTER_ID&timezone=TIME_ZONE
for example: www.gmcmap.com/historyData-plain.asp?Param_ID=64609518812&timezone=-1
This will pull up the last data entry in our database that your counter sent to us.
Example JSON result: {"time": "2018-05-12 0-24:07:13", "CPM": "18", "ACPM": "30.0", "uSv": "0.12"}
If you need more values or anything else we are always happy to help! Thanks again for using GMC geiger counters.
EmfDev Posted - 03/27/2019 : 12:03:59
We will take a look into it.
staze Posted - 03/26/2019 : 16:44:57
Is this something we could get added? Would be nice for integrations with other systems...
EmfDev Posted - 03/26/2019 : 08:54:49
I don't think there is.
staze Posted - 03/25/2019 : 19:35:34
Nothing?
