 FW Update ? GQ GMC-500+ - Firmware Version: 1.16
OkosamaStarr Posted - 12/23/2023 : 02:53:51
GQ GMC-500+ - Firmware Version: 1.16 - MFG Year: 2016
I have issues with the FW (config WiFi and USB Connect).
Question:
1 - waht is the current Firmware for this Model ?
2 - is it possible to upgrade Firmware and reflash the Chip (where can i download Programmer and bin file)?
UnstableIsotope Posted - 12/24/2023 : 19:17:34
I recently got an update from GQ for my 500+.
The latest version as of a couple weeks ago was 2.52.
OkosamaStarr Posted - 12/24/2023 : 06:45:46
Originally posted by Jadeye
@OkosamaStarr write them an email to "support @ gqelectronicsllc . com" with your device serial asking for the firmware update and you will receive a link to a Windows utility that will update your device as well as a link to the USB driver if needed.
The last time I asked them for my 500+ was in early November, and I received version 2.49G.
ThanX ... will try this asap
Jadeye Posted - 12/23/2023 : 12:09:33
OkosamaStarr Posted - 12/23/2023 : 08:54:18
Question:
Epecially got problems to read out data via usb from device - no serial, no user id and other configs... will send console output later... com port is set up correctly and realtime data and data readout works
