 Forum compromised?
bradcarnage Posted - 12/06/2023 : 15:23:15
I recently stumbled across this forum because I was looking for a solution to my unusually high readings when viewing data over serial. link: https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=7262
Well, I wanted to go back to the homepage of the forum but it seems as if the index.html was replaced with one from a script kiddie. See: https://www.gqelectronicsllc.com/forum/
Anyways, I just wanted to make this post to inform all of you to use a completely unique passphrase for the forum, and to change your passphrase if you use the same one elsewhere! Do not give the forum a passphrase you've used anywhere else!
UnstableIsotope Posted - 12/06/2023 : 17:31:49
Yikes! I didn't see that but I never reuse passwords fortunately.
EmfDev Posted - 12/06/2023 : 17:26:31
Yes it seems that it has been hacked. Thank you for noticing, just forwarded it to our devs.
