 EMF-390 High EF readings
Lauerkj Posted - 01/14/2021 : 19:01:22
My EMF-390 was getting reading over 100v/m in many places in my home. I found that if I set it down, the readings were much less. Pick it up and the readings are very high. Should it work like this? If so your manual should say not to hold it if you want an accurate reading!
elizabatha Posted - 02/08/2021 : 20:47:52
You can check EMFs in your home with an EMF meter. These handheld devices can be purchased online. But be aware that most can't measure EMFs of very high frequencies and their accuracy is generally low, so their efficacy is limited.Vous êtes fan des trucs mignons, adorables et Kawaii ? Votre bonheur est disponible sur notre site, le choix des pyjama kigurumi qu’on propose est énorme!
[url=https://www.kigurumistore.fr/shop/]enorme[/url]
EmfDev Posted - 01/19/2021 : 15:09:27
Hi Lauerkj, when you hold the device, the static EF from your body is being detected.
