 EMF 390 and EMF 390-v2
TLCasic025 Posted - 04/26/2020 : 14:38:36
on the various stores I sometimes find the GQ EMF-390 and the GQ EMF-390 v2.
Is it correct? If yes which is the difference?
Stefano
EmfDev Posted - 01/25/2021 : 12:14:15
Hi noarhill,
To enable/disable sensitive mode, go to the RF Settings Menu and hold the down + back button at the same time.
noarhill Posted - 01/24/2021 : 08:46:45
I have just received the GQ390v2 (Rev 3.60; Serial number 360E343236308F) from Amazon UK and it does not appear to have the RF sensitivity setting in the RF settings menu. I particulrly wanted this feature. Have I bought the wrong meter or do I need to download some additional software?
Many thanks
EmfDev Posted - 12/02/2020 : 10:14:15
Hi mikemma, yes it is guaranteed v2 up to 10GHz.
mikemma Posted - 12/01/2020 : 01:36:39
Hi. I would like to order https://www.amazon.de/-/en/gp/product/B07JGJ897T/ref=ox_sc_act_title_2?smid=AKVL4MRYBNW0F&psc=1. From previous messages, should I understand that the product is in fact GQ EMF-390 V2? or V2 can be ordered only directly from your website?
Also, on some websites I saw that the RF limit range for V2 is 8Ghz instead of 10Ghz. Is this true? (on the link above the description says 10Ghz).
Thanks,
Mike
EmfDev Posted - 06/30/2020 : 08:59:20
Hi bibitsi, you can send me your serial number to check for firmware version.
bibitsi Posted - 06/30/2020 : 08:00:09
Hi, I have the EMF 390v2 version, I would just like to ask if there is any newer firmware update for this. thank you..
EmfDev Posted - 04/27/2020 : 13:33:38
Hi Stefano, there is no difference in the listing. The former is probably an older listing but if you order now, you will receive the same version V2.
