 EMF 390 Version 2 has Different Frequency Coverage
Bill D. Posted - 07/04/2020 : 12:34:36
The ver 2 manual of the 390 shows a major change-up for the frequency bands of the Spectrum Analyzer. All the kHz bands have been dropped and the unit does not analyze anything under 50 MHz.
Ver 2: Frequency band 1: 50 MHz -65MHz (FM Radio)
Ver 1: Frequency band 1: 150KHz – 534KHz
Etc. also for other bands
Does this represent a hardware change in the 390?
Is it possible to upgrade the firmware without losing these lower bands?
EmfDev Posted - 07/08/2020 : 09:43:46
The reason why is because of the older spectrum component is not available anymore.
tinzi Posted - 07/07/2020 : 13:15:36
This sounds counter intuitive to me (I'm new to this and curious), but i'm sure it involves a lot of technical considerations to come to this design update, can you simply explain the pros and cons of this design? Thank you.
EmfDev Posted - 07/06/2020 : 10:09:45
In the spectrum yes, it covers less frequency.
Bill D. Posted - 07/06/2020 : 09:45:40
That's interesting. So v2 is not using the full potential of the hardware in terms of frequency coverage.
EmfDev Posted - 07/06/2020 : 09:27:25
Yes, the RF spectrum has changed from V1 to V2. They have different firmware versions but has the same features.
Generated in 0.87 sec. Snitz's Forums 2000
