 use of EMF-390
flash Posted - 12/06/2019 : 12:25:12
I purchased an EMF-390 in hopes of being able to locate the source of interference for the open/close signal for my electrically operated driveway gate, such that I have to be very close to the antenna with the various signal devices to operate the gate when a system of landscaping lights near the gate is on. The EMF-390 appears to be well beyond my technical knowledge, so any help would be greatly appreciated.
wolffmichael Posted - 03/11/2020 : 08:34:47
Thanks!
EmfDev Posted - 03/11/2020 : 08:09:58
Hi wolffmichael, in spectrum band, hold the down button to display the selection screen for the other bands. then press down again once it popped up. then press select/menu key.
wolffmichael Posted - 03/11/2020 : 07:31:48
How can I switch the spectrum analyzer band to 240MHz-1040MHz?
flash Posted - 12/06/2019 : 14:38:07
thank you
EmfDev Posted - 12/06/2019 : 14:13:37
Switch to the spectrum analyzer band to 240MHz-1040MHz. You can see there the remote signal around 310-315 if that's correct. You can zoom in to those values to check.
flash Posted - 12/06/2019 : 14:04:13
The gate people say it is in the 310 to 315 MHz range.
EmfDev Posted - 12/06/2019 : 13:37:49
Hi flash, you need to check in which frequency does your remote operate? You can check the spectrum mode is there's something being detected when using the remote.
