| T O P I C R E V I E W |
| Bill D. |
Posted - 10/21/2019 : 19:36:54 The battery meter is stuck at 100%, even after an hour or so of use. The last time I charged it, it dropped suddenly to 84% after only a few minutes.
Is there a fix? |
| EmfDev |
Posted - 10/24/2019 : 10:20:43 Yes it will stop charging when full and displays Battery Level 100% instead of Charging... |
| Bill D. |
Posted - 10/24/2019 : 06:05:34 That makes sense. Does the unit have overcharge protection or do you need to check the meter while it's charging? |
| EmfDev |
Posted - 10/22/2019 : 09:14:22 Hi Bill D, the battery displays 100% at 4V but if you charge it for more it can go up to 4.2 volts. Thats why you see 100% from 4.2V to 4.0V then you will start seeing the drop. |
