 Is 3-axis readings broken?
pcote Posted - 01/14/2025 : 15:23:04
Hi!
I bought the GW EMF-390 and started using it for various scenarios.
I noticed our neighbourhood get blasted by a strong EMF signal (around 72 mG) every 5 minutes. I tried to pinpoint it using the 3-axis readings. However, no matter the orientation of the device, only the Z axis is able to read that signal.
Is that normal?
Thanks.
EmfDev Posted - 01/17/2025 : 10:37:39
You can email me the serial number so I can send you the latest firmware update.
pcote Posted - 01/15/2025 : 14:37:13
Hi Phil what is the firmware revision on your device? You can find it under Main Menu -> About -> Serial Number.
Hi!
Thanks for your reply. It says revision Re 3.74.
Did you really need the serial number? (is that safe info to share here?)
Thanks.
EmfDev Posted - 01/14/2025 : 16:41:42
