 Dynamic location using NMEA /TAIP? (PepWave router
paulr Posted - 03/03/2022 : 15:05:05
Hello! I have installed my GMC-600 in my vehicle which has a PepWave 4G router to provide internet access. This router is capable of sending a NMEA or TAIP string of location data, on any TCP or UDP port. It can also append a "vehicle ID" to identify the sender. The time interval can also be customized in seconds. Is there a way you could update your system to allow real-time location data to be submitted this way? Also, would it be possible for you to truncate the lat/lon so it only reveals my approximate location, and not exact position (accurate to 100m or 500m)? Thanks!
Generated in 1.04 sec. Snitz's Forums 2000
