 Data viewer 2.40: no units of vertical axis
ocsi Posted - 12/20/2021 : 11:27:39
I recently purchased a GMC-600+ geiger counter and am using the data viewer supplied with it (version 2.40). The vertical axis of the graph does not indicate units. The horizontal axis is marked 0 to 60 with no units shown but it can be deduced that it refers to a 60-second interval but it is not clear to which 60-second interval. When "playing" the data, it is not clear which data is displayed. Is there a more useful version?
EmfDev Posted - 12/21/2021 : 10:35:40
Try to uninstall the data viewer that you previously installed first.
ocsi Posted - 12/20/2021 : 16:42:50
Hi ocsi, there is a newer version 4.63 from the website. https://www.gqelectronicsllc.com/comersus/store/download.asp
Thank you for the information. I only found version 2.63. I suppose you meant this version. When trying to install, the setup wizard stated that it will install version 1.15 which seems to be an earlier version, so I did not install. Please clarify the situation.
EmfDev Posted - 12/20/2021 : 12:54:46
