 Slow Access to URL (json)
John01 Posted - 10/19/2022 : 20:32:17
Hello.
I try to access the url:
hxxp://www.gmcmap.com/historyData-plain.asp?Param_ID=<id>&TimeZone=<tz>
to get the json data of my Geiger Counter but is too slow.
It takes about 18-20 sec every time to fully load the page and get the json data
I think there may be a problem with gq servers.
Can you please assist?
EmfDev Posted - 02/13/2023 : 11:38:12
Hi kotarak, do you mean the log2.asp is broken?
kotarak Posted - 02/10/2023 : 12:25:26
I wonder if there is an ETA when this would be fixed - the URL returns nothing - I use a little widget to report my counter and I get no return. Just an empty string. It was working slow a month ago and sometimes will not get a response but now seems to be permanently broken.
EmfDev Posted - 11/22/2022 : 15:54:07
There usually is a server maintenance at least once a year.
panosip Posted - 11/20/2022 : 20:53:03
I see. Over time the problem should be worst, add additional time will be added.
Is there a solution by modifying the data retention or adding more resources?
EmfDev Posted - 11/15/2022 : 15:42:23
Hi John01, according to support, it seems the database has a tons of data and that causes the slow response.
John01 Posted - 11/10/2022 : 02:59:37
Hello.
Any updates regarding slow loading times? The issue remains
Thanks so much
EmfDev Posted - 10/25/2022 : 10:18:52
Hi John01, I will tell support.
