 A305D
mckkcm001 Posted - 04/16/2015 : 13:23:40
I have a new A305D power supply that only reads 0 for both current and voltage. The red CV light comes on unless both current knobs are turned down, then the green CC light comes on. I opened the case, but did not see any fuse to replace?? Any help would be appreciated.
ZLM Posted - 04/19/2015 : 10:14:04
As long as CC light comes to green, then the unit is in a CC Mode. The voltage knob no longer controls the voltage. The Current knob controls current.
Maximum the current knob, if the +/- output leads are not shorted but the green CC light still on, then something wrong with the unit. Check the output transistor and see if it is burned.
