 Upgrades
U-238 Posted - 12/06/2016 : 06:28:58
Hi, I was wondering if I could upgrade the battery in the GMC-320+. I know it already has great battery life but if I 3d printed a case extension could I upgrade it. Also is it possible replace the mini usb port with a micro usb port for charging. I have one mini usb cable compared to the hundred micro usb cables. Just thought it would be a cool upgrade. Also if I am making an external probe for my gmc320 do I need to raise the tube voltage for the BNC cable that I am using. the cable has a resistance of 75ohms.
ZLM Posted - 12/20/2016 : 19:31:23
Please share your result. Thanks.
U-238 Posted - 12/19/2016 : 12:00:04
Okay, Thanks! My SBT-11A came in today. I will be doing the upgrade tonight.
flukeguy Posted - 12/07/2016 : 14:42:03
BTW, I bet you can find a mini to micro USB adapter pretty cheap! It would be a lot easier to do!
--Terry
flukeguy Posted - 12/07/2016 : 07:35:09
Hi U-238,
Can't give much advice on the extended battery/USB, but, yes, you can use the BNC cable. The 75 Ohms refers to Impedance and wont load down the tube voltage, but keep the length less that 4 feet for best results. I'm using an SBT-11 tube on a 3 foot BNC terminated cable on the GMC320 and it works fine. Great sensitivity.
--Terry
