 320 Plus as a dosimeter?
mpmdembi Posted - 05/13/2016 : 13:32:26
It is possible to see on this Geiger counter total dose recived?
I mean - if I carry it with me in "danger zone", after "trip" can I check what was tota dose in uSv?
Distelzombie Posted - 07/22/2016 : 06:07:44
Well, it could be another selling point for GQ. Maybe they'll do it.
mpmdembi Posted - 07/20/2016 : 07:33:14
Good question :-) Answer is - GQ can be connected to PC.
But, if support promised to add this feature within near future (it's only software problem) it will be added - I believe.
After this upgrade it will be much better then Terra.
Distelzombie Posted - 07/20/2016 : 04:45:30
Why haven't you bought the Terra then?
mpmdembi Posted - 07/18/2016 : 11:57:29
Oh yes! I can also count beeps and divide it by seconds/minutes and get CPM/CPS :-)
Supprt told me about 2 months ago, that they will implement in FW "dosimeter mode" and options with faster (but less accurate) uSv/h (CPM) count. GQ is much slower than for example Terra-P, and Terra-P has also dosimeter mode.
They told me, to do it within couple weeks, but till now no new features in FW :-(
Distelzombie Posted - 07/18/2016 : 02:11:20
You could make a timed count and then simply use the average (if it's working correctly in the new fw) to calculate the dose.
Avg times total hours = dose, I think.
mpmdembi Posted - 07/16/2016 : 11:10:13
Great! Now please tell how to do that! Have you added it to new FW?
ZLM Posted - 07/12/2016 : 16:54:21
That is the simple way. Yes. The GQ is able to add that.
mpmdembi Posted - 05/14/2016 : 07:40:08
Yes, you're right, but...
If Geiger counter is exposed for example 1uSv/h for 1 hour It will receive 1uSv dose. So I would like to know it.
Terra-P can gives you information about total dose in particular time - why Terra can do it, but GQ not?
ZLM Posted - 05/13/2016 : 17:52:12
No.
Because the total radiation received is calculated based on your body weight, height.
Generated in 0.22 sec. Snitz's Forums 2000
