| T O P I C R E V I E W |
| IHA |
Posted - 06/09/2024 : 10:27:34 Hello, my GMC500+ with USB C (2.53IIRC) has the tubes uncovered with black tape, is that normal? Could not profuce false clicks due to light?
Thanks! |
| 1 L A T E S T R E P L I E S (Newest First) |
| EmfDev |
Posted - 06/11/2024 : 15:16:26 Hi IHA, you can easily test it if you go outside under the sun to check for light sensitivity or if you have a UV flashlight. But in normal uses if the readings are normal, then do not worry about it being light sensitive. |
