 GMC-500+ purple flashes
2072 Posted - 04/30/2024 : 11:28:49
My device is sometimes emitting very short and bright purple (electric like) flashes, it seems to be coming from the tubes, is this normal?
2072 Posted - 06/14/2024 : 15:54:41
Ah thank you so much! I could indeed trigger this blue light with the test connection menu. One mystery solved!
EmfDev Posted - 06/11/2024 : 15:10:38
3z_phoenix is right. The WiFi Module has a blue Led that blinks whenever it sends data to the server. Usually, it is on sleep mode when WiFi is OFF or between sending data.
3z_phoenix Posted - 06/06/2024 : 07:29:37
hello,
don't worry, the blue flashing light comes from a small LED good covert inside housing, it flashes when it sends your counting-data to www.gmcmap.com
you can check this, if go into preferences --> Server --> select Test Connection now hit "Enter bottom" for start the test,
it will flash one or two times ...
(first i worry by myself same way, thinking on lightning stroke inside the Tube from overvoltage, but that it is not)
kind regards ;)
3z_phoenix
