 Measurements from Bajkal, Siberia, USSR by igel
igel Posted - 11/14/2023 : 21:51:26
Since 2018, I have been studying radiation from cell towers and radio stations, metal detector frames and anti-theft, ionizing radiation, air and water quality. I measure and record both the power and the content of radiation with round-the-clock monitoring and logging. I post all observations and recordings in social networks and chats. I create radiation measuring devices of different models and protection for the head and body. I live in the Taiga on a hill, 210m above the sea, which is great for amateur radio. My YouTube channel youtube.com/c/#1025;#1078;#1058;#1072;#1105;#1078;#1085;#1099;#1081; in 2019, I was banned for these studies, then restored with a shadow ban, but since then I have been publishing everything in VK, telegram and on my website. Links in the header of the channel.
Education: Instrumentation of the 5th category + Teleradiocommunication + TUSUR Promelectronics, and much more self-education. From the age of 5 to 12, he studied chemistry, conducted about 400 experiments. At the age of 12, he collected digital dosimeters (In Ust-Kamenogorsk there was a background of more than 200mkR/h), and from the age of 14 I made DIY computers: Radio-86RK, Specialist, Spectrum 48/128, Profi 1024+, and then all the production of equipment and parts were ruined and destroyed by the invaders, it became profitable only to trade imports and repair it. In general, I am an infomaniac with Asperger's syndrome, and since I am a loner without a relationship, I spend my whole life studying all kinds of technical sciences and acquiring skills in repairs and coding.
Equipment:
EMI meters of electric, magnetic, and radio fields (EF,MF,RF):
self-made switch RF PPE UHF+microwave+EHF from 300MHz to 120GHz and miniature wristwatches on an LED indicator up to 6GHz with demodulated sound output, and three measurement modes.
American EF+MF+RF GQ EMF-390 from 0.15Hz to 10GHz with a spectrum analyzer and round-the-clock recording, modified with external antennas and sound output,
Chinese EF+MF+RF BR-9 from 0.005Hz with a 1.5/3 minute schedule modified to 6GHz and sound output,
Chinese EF+MF GM3120 from 20Hz modified to 8GHz and sound output;
Oscilloscopes: homemade JYE Tech DSO-138 modified to two-beam up to 200 kHz and two-beam WAVE-2 up to 200 kHz, Chinese two-beam FNIRSI-1014D up to 100 MHz with modifications, and Soviet- service television combine of the Zolochevsky Radio Plant S1-81 up to 20 MHz and Actacom USB dual-channel storage + spectrum analyzer ASK-3102 up to 100 MHz;
Frequency meters: homemade up to 50 MHz, Chinese GY-561 up to 2.5GHz;
Dosimeters: various homemade, American GQ GMC-300E with Wi-Fi markings on the map and Soviet DP-5A;
Receivers: RTL-SDR from 10kHz to 1.8GHz, Calex (TDK) 701SS 535~1650KHz,88~104MHz;
Transceivers: HackRF + Portapack Havok up to 7.5GHz, Baofeng UV-82 Walkie-talkie;
Spectrum analyzers: Chinese TinySA up to 1.2GHz and RTZ up to 4.4GHz + Soviet Arinst SSA-TG LC R2 up to 6GHz + TinySA ULTRA up to 20GHz;
Vector antenna analyzer NanoVNA 2.2 to 4.4GHz.
In addition to ether research:
Air Analyzer 12 parameters, Chemical Exploration Device VPHR;
Water Analyzer 9 parameters, Test strips 16 parameters;
Sound analyzer Digital noise meter iCarTool IC-M102 with an external microphone up to 50kHz, a pressure sensor from 50Hz to constant, and a seismic sensor;
Light analyzer: MASTECH MS6612T luxometer with a set of filters + IR,UV.
A homemade spectroscope made of prisms;
Thermal imager NOYAFA NF-521
The TZS-2 night vision device from the Novosibirsk Refinery with an enhanced OL-1 searchlight and an additional Jupiter 21M 4/200mm telephoto lens
I will describe 5 microscopes and 3 telescopes later.
igel Posted - 12/20/2023 : 07:05:53
Originally posted by GBG12
Hi Igel,
Please try to join Radmon again to see proper graphs. I am on Radmon and there should be no restrictions, it is for experimenters like us.
I can't use it cause radlog doesn't work on win XP and linux.
GBG12 Posted - 11/25/2023 : 20:14:46
Hi Igel,
igel Posted - 11/14/2023 : 22:07:18
CHANNEL FOR STUDYING THE ETHER #128223; #128225; measurements, observations, discussions, inventions of new devices, repeats of my articles and video releases, [30.04.23 16:20]
Good health to all! The radiation waves have stopped, you can write a report. They began at night on about April 15 with waves up to 80 and 180mkR/h, on April 20 there were two waves up to 3300mkR/h. The schedule is the same for everyone - the wave front is about 5-15min, then a flat plateau of 20-40min, and the decline is twice as fast. Since it was difficult to catch the beginning, I recorded graphs and videos only of the completion of the waves. Looking for similar cases on radioactivity monitoring maps, I found exactly the same waves in Magadan narodmon.ru/3199
Waviness is also traced at a "normal" level, even by ear = the dose cracks more often, then less often every minute, and longer waves of 90-120min are tracked on the graph. At the same time, EMF-390 did not react to them.
I did not understand their nature, neither the laboratory assistants nor Ozharovsky helped. Since the service of my device www.gmcmap.com/historyData.asp?Param_ID=19660136604&KEY=648 does not show graphs, but narodmon.ru and radmon.org they do not allow me to add my device for online monitoring- the log is kept in the RadLog program.
In the continuation of the post links to the video:
180mkR/h waves at night..mp4 size 557MB t.me/igeliztz/26864
180mkR-h night waves 666kbps.mp4 size 15MB t.me/igeliztz/26865
6699CPM day waves 4.20.2023.mp4 t.me/igeliztz/26994
