 GMC-500+ and captured off-line data upload
kmartynov
Posted - 10/07/2022 :  07:09:16  Show Profile  Reply with Quote
I searched the forums a bit, but could not find the answer. Is it possible to log the data on GMC-500+ while the counter is not connected to WiFi and then, once connection is available to upload the data? This way there are no gaps in the log.
Thanks.
Posted - 10/07/2022 :  09:25:03  Show Profile  Reply with Quote
Hi kmartynov, unfortunately, the feature is not present in the GMC-500+ and others
kmartynov
Posted - 10/07/2022 :  11:25:31  Show Profile  Reply with Quote
Thanks EmfDev! The workaround would be to switch to cell phone's hotspot wi-fi SSID while normal wi-fi is not available. It will require to set hotspot SSID name/password the same as "home wifi", otherwise one will have to re-enter both values every time - pain.
Is there a "feature request" page for counters where people can submit their ideas?
Thanks.
Posted - 10/13/2022 :  09:21:58  Show Profile  Reply with Quote
Hi kmartynov, there is no page for feature ideas as of yet.
Does the workaround work? It will not automatically connect to another hotspot unless you try to connect again with the same wifi parameters.
