 Which comm port to use for USB connection and how
singh
India
Posted - 08/15/2019 :  04:04:26  Show Profile  Reply with Quote
I have setup the viewer and logger software on a Windows 7 system, but the meter (300E Plus) is not connecting to the software. Can someone guide with the steps to be followed?
I plan to buy the Pro software version, but I want to be sure that I can connect with USB port first, otherwise it doesn't serve any purpose.
Posted - 08/15/2019 :  09:08:01  Show Profile  Reply with Quote
Hi singh, you can use any port for your meter. Just make sure the port number is correct.
Once you plugged in your device, check your computer's device manager for the port number. Look under Ports for USB-SERIAL CH340. And use that port number on the data viewer to connect.
singh
India
Posted - 08/15/2019 :  11:45:13  Show Profile  Reply with Quote
Will this work without first buying the pro version of the software?
Posted - 08/15/2019 :  11:47:10  Show Profile  Reply with Quote
Yes it should work.
