| Reply #1
2411 Posts |
Posted - 01/19/2018 : 12:44:33
1. The XYZ emf can detect minimum 1Hz and up to 300MHz but sensitivity is not linear. Lower frequency has higher sensitivity. 2. In RF measurements, the dBm represents the signal strength, which is the same as the power alone. There's no way to get power/m^2 from dBm, Unless it's dBm/m^2 3. HiFrq measures 300MHz - 7GHz EMF in milliGauss. 4. RF power only available in RF spectrum graph which are only available in those 6 bands/frequencies. |
Edited by - EmfDev on 01/19/2018 12:46:05 |
