 making data upload to map
fatmat
Posted - 06/08/2017 :  15:14:37  Show Profile  Reply with Quote
howdy im mat in hatch,nm.u.s.a.. im having a hard time getting data from my area to upload into the map system...
im pretty sure i down loaded all i need and software disc is on file in the run mode...
does it take time or is it instantly visible/?some one kindly set this amateur strait i've got a GMC-320+geiger muller counter\data logger...thanks folks
m.r.smith
Edited by - fatmat on 06/08/2017 16:05:24
Posted - 06/11/2017 :  21:29:13  Show Profile  Reply with Quote
In order to upload the real-time data to the GMCmap, you need two IDs: the GMCmap account ID and GMCmap Geiger Counter ID.
Then from the software Data Viewer, you need to input those IDs into the menu Geiger Counter World Map.
Click on the Verify button in the menu dialogue Window.
Make sure you checked the Enable Auto Submit Data check box too.
From Data Viewer main Window. check the Real-Time monitoring check box.
Than the data will be automatically uploaded into GMCmap.
Generated in 0.45 sec. Snitz's Forums 2000
