 Difficulty with display type on GMC-320
radrunner44
Posted - 10/20/2014 :  14:04:33  Show Profile  Reply with Quote
I have a new GMC-320. When in the menu to select the display type, the unit "times out" before I can press the up or down buttons to scroll through the choices. Can this timeout be changed, or is this maybe a known issue? Further, sometimes, the display type will spontaneously change from one to another, eg. if I am in large font and testing a sample, it will frequently simply change to either text or graphic without my input. I have even seen it almost scroll through all three choices while testing. Any ideas? Thanks
Posted - 10/20/2014 :  21:24:20  Show Profile  Reply with Quote
For the problem on "spontaneously change display type", turn off the motion detection in the menu. Little vibration may trigger the motion detector.
The popup window timeout will be fixed in the later firmware.
