 GMC-320 Plus stops after 128 samples
fmotl
Posted - 09/25/2014 :  13:54:38  Show Profile  Reply with Quote
Hi there,
Just got a GMC-320 plus. I'm using it with pyRadMon on a Linux PC. It works great however the sampling stops after 128 samples with the following error.
Problem in getData procedure (disconnected USB device?): (5, 'Input/output error').
See Python code below.
When I start the problem (without doing anything else such as unplugging/replugging the device), it works again for 128 samples, then stops again. As far as I can tell the device is operating normally - observing what I see on the display.
Any suggestions?
cheers,
Fred
try:
  # wait for data
  while (self.serialPort.inWaiting()==0 and self.stopwork==0):
    time.sleep(1)
  time.sleep(0.1) # just to ensure all CPM bytes are in serial port buffer
  # read all available data
  x=""
  while (self.serialPort.inWaiting()>0 and self.stopwork==0):
    x = x + self.serialPort.read()
    if len(x)>0:
      cpm=int(x)
    utcTime=datetime.datetime.utcnow()
    data=[cpm, utcTime]
    return data
except Exception as e:
  print "Problem in getData procedure (disconnected USB device?):", str(e)," exiting!!!"
  self.stop()
  sys.exit(1)
Posted - 09/26/2014 :  15:50:21  Show Profile  Reply with Quote
What are you sending to device?
You may need change the Exception location to narrow down to a particular code line. That is easier to find out the problem.
fmotl
Posted - 09/30/2014 :  16:16:37  Show Profile  Reply with Quote
Hi all,
Turned out to be a problem with the USB HUB.
I guess it failing after 128 samples was an interesting coincidence!
All good.
thanks,
Fred
Edited by - fmotl on 09/30/2014 16:16:57
