| Author |
Topic  |
Pheckphul
8 Posts |
Posted - 03/30/2014 : 16:53:44
The GMC-320 plus' page does not list a battery as part of the contents. Is this an error, or does it indeed NOT come with a battery?
What type of 14500 battery does the unit use? As it is removable I'd expect it to use a button-top with a protection IC. Is this the case, or does the battery holder only accommodate flat-top 14500s? |
| Reply #1
sim_v
4 Posts |
Posted - 03/31/2014 : 00:42:31
Yes, a removable rechargeable battery is included. And yes, it's not clear in the full description. |
-- France |
Edited by - sim_v on 03/31/2014 00:42:55 |
| Reply #2
1271 Posts |
Posted - 04/01/2014 : 12:08:18
| The GMC-320 Plus installed a rechargeable battery. The battery is 14500 3.6V. The battery is removable, you can install other 3.6-3.7V battery. The battery holder accept with button-top 14500 battery. The protection IC is build-in with the GMC-320. When a non-rechargeable battery installed, you should select the "Non-Rechargeable" battery type from the unit menu. |
| Reply #3
Pheckphul
8 Posts |
Posted - 04/01/2014 : 21:21:26
| I got my GMC-320Plus on Monday. I see you used a Tenergy battery. I've been using their batteries for a couple of years and have been happy with their bang-for-the-buck. Not as good as Sanyo, but much cheaper. I also conveniently live about 25 miles from them, so that's a bonus. Unfortunately, judging from their retail site www.all-battery.com, they don't make a button-top 14500. I'll give a call and verify. |
| Reply #4
Nisei
Netherlands
20 Posts |
Posted - 10/19/2015 : 02:04:00
quote: Originally posted by ZLMWhen a non-rechargeable battery installed, you should select the "Non-Rechargeable" battery type from the unit menu.
Do non-rechargeable 3.7V AA/14500 size batteries even exist? |
John |
| Reply #5
1271 Posts |
Posted - 10/19/2015 : 13:21:43
Yes. Examples: 1. Tekcell SB-AA11 3.6V 2. XENO ER14505 3.6V AA
They are last much longer than the chargeable battery . I have tested with Tekcell SB-AA11 on GMC-320. It continually ran for more than a week.
| Reply #6
Nisei
Netherlands
20 Posts |
Posted - 10/23/2015 : 14:29:35
Ah thanks. I didn't know these existed. Which raises another question: can you change the battery quickly with the unit continuing to measure/log data (by using a capacitor), or does it stop as soon as you take out the battery? |
John |
| Reply #7
1271 Posts |
Posted - 10/24/2015 : 08:56:15
| It stops working if you take out the battery. |
Topic  |
