 GMC-300: CPM to uSv/h & mR/h conversion
CPM
Posted - 11/17/2012 :  12:18:59  Show Profile  Reply with Quote
I took some measurements yesterday and I saw a similar calibration/conversion issue that ska had seen in his topic
with TOPIC_ID=3669 http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=3669
Edited by - CPM on 12/15/2012 00:13:47
CPM
Posted - 11/17/2012 :  15:11:37  Show Profile  Reply with Quote
I guess, this might be because the GMC-300 could have been factory calibrated at three different points, possibly with different sources...if this is the case, now the question is: How can we avoid having such a significant jump (especially, a drop) in uSv/hr & mR/hr reading as a function of CPM?
I love my GMC-300 by the way... It is a well-made device.
Edited by - CPM on 12/15/2012 00:20:53
Posted - 11/18/2012 :  23:42:33  Show Profile  Reply with Quote
The GMC-300 is able to calibrate to different range. This is useful when you working on a different radiation range and need a accurate reading.
The default calibration covers 0-1000 CPM. This covers most regular mornitoring level for a accurate reading(<1000CPM). From 1001 and up, the value will be estiminated from the lower calibrated data. This is why the jump point is at the 1000CPM.
Here is a calibration example:
If you are measuring high range (>1000CPM) and you need a accurate reading. Then you need change those calibration data.
But before you do that, you need to know what CPM range you want to calibrate. We know the CPM to uSv/h and mR/h convertion is not a simple liner convertion, so we are unable to calibrate the unit from 0 to infinity for a high accurate reading in full range. So, we must define a calibration range for a better convertion. Assume you are going to use it in a range 2000CPM to 3000CPM, then you may set the calibration data points as :
#1, CPM = 1000, uSv/h = 9.00 (the value we know at the 1000CPM)
#2, CPM = 2000, uSv/h = XXXX (the value you know at the 2000CPM)
#3, CPM = 3000, uSv/h = XXXX (the value you know at the 3000CPM)
With those calibration data, the range calibetated are : 0-1000CPM, 1001-2000CPM and 2001-3000CPM.
When CPM with in 0-1000, it uses #1 conversion rate.
When CPM with in 1001=2000, it uses #2 conversion rate.
When CPM with in 2001=3000, it uses #3 conversion rate.
If you have a better calibration way, please let us know.
CPM
Posted - 11/19/2012 :  11:25:03  Show Profile  Reply with Quote
Yeah, that makes sense... This scheme is better than the ones that use only one conversion ratio for all regimes. At least, this method gives users more flexibility.
There are more elaborate calibration methods out there, but either they are not worth the trouble (for general use) or they are very application and source specific. I think this 3 point calibration is good enough. Thanks for the clarification.
Edited by - CPM on 11/22/2012 10:35:11
and_kom
Ukraine
Posted - 11/22/2012 :  14:17:15  Show Profile  Reply with Quote
FYI, during Chernobyl Zone trip I've noticed that at high radioactive spots GMC-300 was showing less uSv/h (mR/h) reading than regular dosimeters.
At very high radioactive spots (about 1-2 mSv) GMC-300 stopped emitting sound and maybe counting (seems due to high current consumption by GMC-300 circuit).
Young and radioactive
Posted - 11/22/2012 :  18:36:11  Show Profile  Reply with Quote
"emitting sound" takes lot of power. When at high frequncy sound, it takes much more power than counting and saving feature.
It is good to hear the sound at the low counting level. But it is better to turn off the sound if you are measuring high level. so that to save the power to counting and other features working correctly.
and_kom
Ukraine
Posted - 12/28/2012 :  09:07:33  Show Profile  Reply with Quote
What if there will be more than 3000 CPM?
What is the default conversion rate?
Posted - 12/28/2012 :  22:45:08  Show Profile  Reply with Quote
It selects the last rate used.
and_kom
Ukraine
Posted - 01/03/2013 :  11:08:02  Show Profile  Reply with Quote
I did the following testing to better understand the conversion algorithm and got confusing results.
Calibration data used:
Calibrate 1: 5 CPM = 0 uSv/h
Calibrate 2: 10 CPM = 0.1 uSv/h
Calibrate 3: 20 CPM = 0.75 uSv/h
Results:
CPM uSv/h
0 0
1 0
2 0
3 0
4 0
5 0
6 0.12
7 0.14
8 0.16
9 0.18
10 0.10 - ???
11 0.72 - ???
12 0.78
13 0.85
14 0.91
15 0.98
16 1.04
17 1.11
18 1.17
19 1.24
20 0.75 - ???
21 0.07 - ???
22 0.07
23 0.08
24 0.08
Could you give better explanation of the formula used and why there are significant uSv/h drops after 9, 11, 19 and 20 CPM?
Btw, in the Calibrate 3 menu CPM decrease step is 100, but increase is 232. Also in the same menu uSv increase/decrease steps are 1.00 uSv/h. So I was unable to set accurate values.
Edited by - and_kom on 01/03/2013 11:11:12
Posted - 01/05/2013 :  01:22:47  Show Profile  Reply with Quote
I think it worked this way:
0-5 CPM. Use Calibrate 1.
6-10 CPM. Use Calibrate 2
11-20 CPM. Use Calibrate 3
>20 use some thing default.
The value inconsistent/jump can be eliminated by increase the 3rd calibration range. Example,
Calibrate 1: CPM = 60, uSv/h = 0.3
Calibrate 2: CPM = 240, uSv/h = 1.2
Calibrate 3: CPM = 1000, uSv/h = 5.0
I believe this is the best calibration for the general testing and it should be used as factory default. so that to avoid the confusion on the calibration settings and keep the conversion value linear.
and_kom
Ukraine
Posted - 01/09/2013 :  10:17:46  Show Profile  Reply with Quote
For users who use SBM-20 instead of stock m4011 tube: conversion ratio for this tube is 175 (uSv/h = CPM / 175), so
calibrate settings should be:
Calibrate 1: CPM = 60, uSv/h = 0.34
Calibrate 2: CPM = 350, uSv/h = 2.00
Calibrate 3: CPM = 32000, uSv/h = 182.85
FYI in SW version 2.21 max CPM value is 32768 then if you try to increment you will get negative value.
Edited by - and_kom on 01/09/2013 10:18:17
Distelzombie
Posted - 08/03/2016 :  01:07:16  Show Profile  Reply with Quote
Oh interesting. Thanks that you dug it up, dude.
Generated in 0.15 sec. Snitz's Forums 2000
