Bash script stopped working.
Mercator
Netherlands
Posted - 08/27/2025 : 20:40:46
My homebrew geigerounter, built around a RPI zero uses a bash script to send the data to GMC. Worked allright until some unspecified moment. I recently found out about that. The string in the script was:
exec=`wget -O /dev/null "h_t_t_p://
www.GMCmap.com/log2.asp?AID=XXXXX&GID=XXXXXXXXXXX&CPM=$line&ACPM=$gem&uSV=$sievert
Had to change it to:
exec=$(curl -s "h_t_t_p://
" -o /dev/null)
If some other tinkerer has had the same problem, try using this approach.
(BTW remove the underscores)
Generated in 0.12 sec.
