 Custom Server
Nikeware
Posted - 08/26/2023 :  09:04:21  Show Profile  Reply with Quote
Hallo All!
Is it possible to send data direct from device (GMC-500+) to own server?
I created local server in my home intranet and configure device with next:
Server: h**p://localhost:90/
URL: index.php
But "Test connection" command from menu said "Link Server Failed" :(
Periodically I see "WiFi Data Send Failed" message also.
With default server (h**p://gmcmap.com/) and URL (log2.asp) all work fine.
Thanks!
Posted - 08/28/2023 :  09:56:51  Show Profile  Reply with Quote
Did your server receive the the data? You should respond with "OK.ERR0"
Nikeware
Posted - 08/29/2023 :  00:45:53  Show Profile  Reply with Quote
Thank you for answer!
If I try enter the url direct in browser, like this:
h**p://localhost:90/index.php?AID=0230111&GID=0034021&CPM=15&ACPM=13.2&uSV=0.075
it is work fine. Server recieved data and of course answered with "OK.ERR0".
But it is not work direct from device itself.
The "OK.ERR0" answer are there simple text or something another?
If I try enter in the browser url, like:
h**p://gmcmap.com/log2.asp?AID=<my_used_id>&GID=<my_device_id>CPM=15&ACPM=13.2&uSV=0.075
I have answer with "OK.ERR0", but in "Developer Tool" window of the browser (F12) this answer look like 4 lines, were "OK.ERR0" itself placed on the last line.
Posted - 08/29/2023 :  10:54:00  Show Profile  Reply with Quote
is there any response from the device? Like popup error message?
It is just a simple string OK.ERR0.
Nikeware
Posted - 08/29/2023 :  23:27:11  Show Profile  Reply with Quote
First, from my side there are some small fail :-)
I need use not "localhost", but real ip of my PC in local intranet where the server itself located, of course :-)
In other words, we must configure GMC device with the next settings, like this:
Server: h**p://192.168.178.10:90/
URL: index.php
Where 192.168.178.10 is my server in my local intranet.
Unfortunately this is also not work :-(
On device, if I try activate "Test connection" command from menu, I see "Link Server Failed" error message and periodically, "WiFi Data Send Failed" also.
Posted - 08/30/2023 :  04:59:09  Show Profile  Reply with Quote
The problem with the GQ counters is that they do not support configuration of ports. But using port 80 requires receiving software to be run as admin. Mostly a bad choice.
I have added to GeigerLog a "Relay" software, which is run as admin, and translates to any port you want.
All GeigerLog stuff is found here: https://sourceforge.net/projects/geigerlog/
But this relay is only avaialble in a pre-release version of GL1.5. Take the latest from here: https://sourceforge.net/p/geigerlog/discussion/devel/
Then in the gtools subdir of GeigerLog find the GLrelay.py software and instructions for use.
Nikeware
Posted - 08/30/2023 :  10:19:16  Show Profile  Reply with Quote
The problem is probably something else. I have reconfigured my local server so that it
now works without specifying a port. Something like this:
Server: h**p://192.168.178.10/
URL: index.php
Nothing has changed. Test connection is failed. Please note that I have tried
to access this address from my other home devices and everything works fine.
After that, I transferred this code to my server on the Internet to an address like: h**p://gmc.myhome.com/
The result is the same error.
Posted - 08/30/2023 :  22:33:36  Show Profile  Reply with Quote
Read the references I gave you. It will also direct you to the GeigerLog manual, chapter "WiFi Devices – WiFiClient Devices" to learn about a hack needed for an Apached server to make it "unsafe"!
ragesh
India
Posted - 07/11/2024 :  00:19:28  Show Profile  Reply with Quote
Required Custom Server can you porovde us or you host the server
r.m.shah
